Hi, my water has been leaking badly out of the exspansion tank, did a sniff test and basicly needed a new head gasket, so changed that and the water pump, thermo stat is new but its still leaking throu the exspansion tank but not as bad, ive read it could be the seal on the exspansion tank but the pipes are pressurerizing,(are they pressurerizing too much? if so what would cause this ?) would this not be possible if the seal was faulty? if its not the seal what other problem could it be?
plz any advice would be very helpful..
