i've not had this problem on my car but when I worked as a mechanic, occaisionally we had this problem with a few makes of battery. An easy mistake is to have the clamp upside down/back to front. (Just a thought) Providing it's the correct battery power wise, try sliding a small piece of wood between the clamp and the base of the battery. As long as the piece of wood is no more tha 1 cm thick and about the same length as the clamp it should tighten enough to hold your batteyr in place without being seen. Not ideal but it will stop the battery from sliding about,
Kevin
