juliet 0 Posted December 5, 2008 Report Share Posted December 5, 2008 To cut a long story short, the car was running like a dream then whilst driving along it started spluttering and wouldnt run. I stopped the car disconected the battery ( quick reset ) and nothing. Disconnected the MAF and car wont tick over but once going goes like you know what off a hot shovel. With it connected the MPG goes down to 7 but unconnected up to 21 mpg. when it was running fine it did 27 mpg. iv replaced the Lambda, iv had 4 MAF's all second hand with no difference when iv tried them. Surly not all 4 can be broken. Iv hunted the net to find out if you can self test these old style MAF's and found nothing. It does have the old 2 pin connectors for diagnoisis but due to the fact a friend that works at VW factory in Germany says this is a rare exsample of the very earliest VRs not alot can be gained from this early diagnostic system. Not sure what to do really Link to post Share on other sites
Damo 85 0 Posted December 5, 2008 Report Share Posted December 5, 2008 have you tried the usual plugs/leads/coilpack route?? Link to post Share on other sites
