speedmont 0 Posted November 28, 2008 Report Share Posted November 28, 2008 hi all, please help, ive got an 1997 golf vr6 , thats starting to overheat, the fans do kick in ,cos there still on after engine is switched off, not lost any coolant or water from the system, and im getting heating from the climate control. any ideas?cheers Link to post Share on other sites
Dave Lea 4 Posted November 28, 2008 Report Share Posted November 28, 2008 stat prob check all pipes are hot to the rad if 1 is cold then it is more vthan likely the stat Link to post Share on other sites
speedmont 0 Posted November 28, 2008 Author Report Share Posted November 28, 2008 i thought if it was a stst prob, the fans wouldn't kick in Link to post Share on other sites
Dave Lea 4 Posted November 28, 2008 Report Share Posted November 28, 2008 they can seen it b for just make sure the coolant is circulating with no cool pipes Link to post Share on other sites
speedmont 0 Posted November 28, 2008 Author Report Share Posted November 28, 2008 sweet, will try that out, so far i aint got mayonase in with the oil.cheers for the help, let you know how i get on Link to post Share on other sites
speedmont 0 Posted November 30, 2008 Author Report Share Posted November 30, 2008 got a cold pipe so must be stat then? Link to post Share on other sites
Damo 85 0 Posted December 1, 2008 Report Share Posted December 1, 2008 yep, prob stuck shut like mine did mate, fairly straight forward fix, might be worth buying a lower temp stat whilst your getting it all sorted Link to post Share on other sites
KMG 0 Posted December 4, 2008 Report Share Posted December 4, 2008 Sorry to be a bit slow on the uptake but what do you mean by a stat. My VR6 seems to have the same problem. The water temp stays normal but the oil goes up to 110deg (it used to run in the 70-80deg range. I've done a oil/filter change but its made no difference. any ideas? Link to post Share on other sites
Damo 85 0 Posted December 5, 2008 Report Share Posted December 5, 2008 if ur water temp is bang on 90 ur stat (thermostat) is prob fine. also how is the car being driven for it to reach 110?? its not mega hot for a vr but if your flooring it, 110 sounds about right. mine runs with water at 90, oil at 94ish, once warmed up and driving normally.. Link to post Share on other sites
KMG 0 Posted December 9, 2008 Report Share Posted December 9, 2008 That's the wierd thing, it's just driving normally doing no more than 30-50mph. It normally runs between 70-85 deg max. I changed the oil temp sender today and it's still going up to 100-110 deg. I guess the next thing is a coolant flush. After that i'm all out of ideas. Link to post Share on other sites
Damo 85 0 Posted December 10, 2008 Report Share Posted December 10, 2008 yeh be worth trying a coolant flush as i think an airlock in your coolant system would have the same sort of effect. does seem pretty warm for 30-50mph driving. unless you going everywhere in 2nd gear LOL Link to post Share on other sites
gavinvr6 0 Posted December 10, 2008 Report Share Posted December 10, 2008 as per damo 85. flush the coolant through and bleed it correctly. my water sits at 70'c when driving and 90'c when in traffic. and the oil sits at about 90 around town and 95-98 at motorway speed, the only time my oil gets upto 110'c is when im driving like a twat or if the oil gets low. Link to post Share on other sites
peeriehutchie 0 Posted December 14, 2008 Report Share Posted December 14, 2008 had nightmares gettin mine to cool, one of the biggest helps was new knock sensor, was runnin on full retard, renewed everything n now it runs too cold Link to post Share on other sites
