S.i.m.o.n 0 Posted November 20, 2008 Report Share Posted November 20, 2008 Hi,I have a 93 VR6 for the past month it has been dieing. Your be driveing all will be fine then all of a sudden it will slowly lose power and die, if you leave it for 5 mins it will start again but as soon as you get to a constant speed it will slowly lose all power, have tried to hook it up to diagnostics but my ecu will not talk, i have changed the fuel pump, fuel filter, fuel pump relay, cam sensor, crank sensor and im going to put another ecu in it at the weekend. If this does noy work i am at a complete loss as to what it could be so any help will be really apreciatedThanks Simon Link to post Share on other sites
VR6Pete 1,455 Posted November 20, 2008 Report Share Posted November 20, 2008 first of all, try resolve communication to your ECU. check the obd plug is connected up correctly.My MAF was doing stupid things last week, which caused all sorts of problems that looked like it was caused by other things, was intermittent, but got worse and worse, its an easy item to swap /test if you know someone else with the same MAF ...pete Link to post Share on other sites
finny 0 Posted November 20, 2008 Report Share Posted November 20, 2008 Lose power and then 'die' = stall/ engine cut out; don't knowLose power......nothing nothing and then come back up on power; might want to check/ renew the lambda sensors. Link to post Share on other sites
S.i.m.o.n 0 Posted May 14, 2009 Author Report Share Posted May 14, 2009 Just to let people know this fault on my VR6 turned out to be the fuel in the tank, I changed the whole tank and pump and its been fine since, Cheers for the help though guys. Link to post Share on other sites
