chiffchaff 0 Posted November 10, 2008 Report Share Posted November 10, 2008 Hi - please can you help with a problem i have with my VR6?It is a 1997 highline with 67k the clock (genuine too!) when i depress the clutch the revs stick and there is a delay before they drop making me look like a learner driver!this is far worse when i am in reverse - almost as if the choke is on. There is no fault codes coming up and it's driving me mad!!! Link to post Share on other sites
Roan 0 Posted November 10, 2008 Report Share Posted November 10, 2008 Sounds like your throttle body needs cleaned. See the guide here: http://forums.vwvortex.com/zerothread?id=1116399You should really perform TB adaptation on VAG-COM afterwards as well (as per the guide) but turn the ignition on, wait for the buzz and it should reset. Start the car and after a few miles driving should be like driving a different car... Link to post Share on other sites
xyber 1 Posted November 10, 2008 Report Share Posted November 10, 2008 Mine did that when the lambda was on its way out Link to post Share on other sites
jec 0 Posted February 4, 2010 Report Share Posted February 4, 2010 when i depress the clutch the revs stick and there is a delay before they dropI've got the same problem, did you ever get to the bottom of it? Link to post Share on other sites
vr6stormt 0 Posted February 4, 2010 Report Share Posted February 4, 2010 have you checked all your vacume hosses Link to post Share on other sites
