Phat VR6 3 Posted September 17, 2008 Report Share Posted September 17, 2008 Ive been messing around down behind my dash and fuse box fitting my electric window loom and Central locking. All has gone well but now after finishing the job my speedo doesn't work...Ive checked the 2 blue plugs that go into the fuse box with all the white wires on them that goes up to the clocks and there both plugged in properly without any pins pushed out or any visual brakes in the wires Is there any other wires, fuses, relays down there that have any think to do with the speedo, Everythink else works on the clocks....I think ive disconnected something down there... eather that or im just unlucky enough for my somthink else to have broken on me at the same timeThanks for any help Link to post Share on other sites
sparkz 0 Posted September 18, 2008 Report Share Posted September 18, 2008 There is also a 3 pin black plug which is linked to the 2 blue plugs. Have you got indicator signals on the dash clocks? Link to post Share on other sites
Phat VR6 3 Posted September 19, 2008 Author Report Share Posted September 19, 2008 There is also a 3 pin black plug which is linked to the 2 blue plugs. Have you got indicator signals on the dash clocks?Yep everything else works, Sounds promising ill have a look for it cheers, Link to post Share on other sites
Phat VR6 3 Posted September 21, 2008 Author Report Share Posted September 21, 2008 found that plug and all is good there, Think its time to assume somthink else has broken as the same time Link to post Share on other sites
xyber 1 Posted September 21, 2008 Report Share Posted September 21, 2008 the main connector on the back is normally a good place to look, dry joints are common the auto-spark at my local lucas services told me when my tacho was playing up Link to post Share on other sites
