mintie 0 Posted August 23, 2008 Report Share Posted August 23, 2008 i have a 1992 vr6 and have owned it for 7 months and have now clocked 121,000 miles.a recent problem being a bad miss fire and very underpowered with the oil pressure light coming on every now and then. the engine itself has a tapping noise and the sound of a pump whirring. could this be the air flow meter or is this something more technical. Link to post Share on other sites
UnitedMotorsport 55 Posted August 23, 2008 Report Share Posted August 23, 2008 Have you checked the oil? Link to post Share on other sites
mintie 0 Posted August 24, 2008 Author Report Share Posted August 24, 2008 yes oil level is fine. i checked the vr6 manual and it says that its nothing to do with oil level but oil pressure. Link to post Share on other sites
FishWick 21 Posted August 24, 2008 Report Share Posted August 24, 2008 Find someone near you with VAG-COM. Make sure the ECU isn't unhappy before delving into the mechanicals. A dead cam sensor will lose you 30hp and a dead / dying coilpack will cause misfires and lumpy performance.Air flow meter will cause problems aswell if it's knackered..... prepare yourself for a shock for a new one. They're about £300 from VW!VR6 oil pumps are noisy when cold, but should be silent when hot. Link to post Share on other sites
mintie 0 Posted August 26, 2008 Author Report Share Posted August 26, 2008 cheers bud have to look into those things. Link to post Share on other sites
