DAZVR6 0 Posted July 24, 2008 Report Share Posted July 24, 2008 Want to do my 1st oil change on my vr as my sump plug is leaking and needs replacing coz its been caught on far to many speed humps, anyway im off to the stealers on friday to get oil, oil filter and a new sump plug and washer. Will i need anything else..? also any tips as ive never changed oil on a car by myself before..? Link to post Share on other sites
orangecruz 0 Posted July 24, 2008 Report Share Posted July 24, 2008 you will need something to drain the oil into halfords sell one not sure how much though would run the engine for a few min till the oil gets warm that way you get it all out aprt from that its quite straight forward Link to post Share on other sites
craggsy 91 Posted July 24, 2008 Report Share Posted July 24, 2008 5.5litres of oil needed and if you have a TPS near you synta silver is £11.75 for 5 litres inc VAT.Get engine up to temp as oil will flow better but will be hot so let it cool down from full temp. I run mine for about 10 mins or so just so temp flicks to 50. Take out sump plug first and let it drain then try and move whatever your catching oil in so it goes under both sump and filter. Then take small drain screw out of filter housing to empty oil outta that. Then take off housing and replace filter Link to post Share on other sites
dre199 0 Posted July 25, 2008 Report Share Posted July 25, 2008 im also goin to do an oil change and fuel filter change, i have free unlimited access to mobil 1 0w-40 motorsport oil, can anyone tell me will this be ok to change it with? also does anyone have part numbers for a '97 oil filter and fuel filter? Link to post Share on other sites
DAZVR6 0 Posted July 25, 2008 Author Report Share Posted July 25, 2008 Cheers lads, much appreciated. Link to post Share on other sites
DAZVR6 0 Posted July 26, 2008 Author Report Share Posted July 26, 2008 Does the oil filter housing have to be torqued to 22lbs or can i just do it as tight as i can as i don't have a torque wrench to hand? Link to post Share on other sites
fritzenberg 3 Posted July 27, 2008 Report Share Posted July 27, 2008 im also goin to do an oil change and fuel filter change' date=' i have free unlimited access to mobil 1 0w-40 motorsport oil, can anyone tell me will this be ok to change it with? also does anyone have part numbers for a '97 oil filter and fuel filter?[/quote'] i think 0w-40 might be too thin mate.most folk on here use 10w-40 Link to post Share on other sites
Jk* 0 Posted July 27, 2008 Report Share Posted July 27, 2008 So easy, even i did mine! Link to post Share on other sites
jims13 6 Posted July 28, 2008 Report Share Posted July 28, 2008 ive run 0-40 before, its too thin..and i would'nt use it again in a vr. Link to post Share on other sites
