hellsVR6 0 Posted July 14, 2008 Report Share Posted July 14, 2008 Hello everybody peeps. Yes I know, it's been aaaaaaages since I've been on here! (apologies!) However I've been playing with my 1968 Beetle a lot for the past few months (and I lurve it!)But I thought I'd tap into the vast VR6OC knowledge bank that is....err...you lot! haha!I'm getting a rattle which appears to be from my exhaust (fairly new, i.e. less than 9mths old) Milltek exhaust. I am sure it is not the exhaust itself that's hanging off or anything because it's pretty darn solid, i.e. it doesn't move when you give the tail pipe a wiggle.This happens when idling/sat at the lights etc only when I have my Auto MK3 VR6 left in the 'Drive' position...it stops when I plop it back to 'N' or 'P'.I've tried to have a read up on here and I'm hoping it's something and nothing really, I think there was a thread where someone had a similar problem and it was the exhaust heat shield rattling??Anyone got any ideas for me please? It's MOT time next week and I don't want to be forking out ££££'s that I don't have to get anything major fixed just right now.I thankyooo!Helen x Link to post Share on other sites
Dr.Pepper 0 Posted July 14, 2008 Report Share Posted July 14, 2008 I had a heat shield rattle at one point. It would resonate at a certain rev range. Link to post Share on other sites
hellsVR6 0 Posted July 14, 2008 Author Report Share Posted July 14, 2008 Sounds about right then. It goes when I give it gas, so at a low rev range.Is it a 'replacement' job or can it be easily glued back together, lol?Ta Link to post Share on other sites
gti-r-vr6 0 Posted July 14, 2008 Report Share Posted July 14, 2008 I recently had the same sort of issue but it was my cat converter falling apart!I knew it had issues because when i changed my back box i found chunks of it in there.In the end the exhaust got blocked and the car would not rev over 5000rpm very well,so i had to sort it out.Mine used to rattle in the low revs just cruising and pulling away,and some times on start up.Try getting under your car and give the exhaust a good tug about and see if you can hear where the rattle is coming from. Link to post Share on other sites
Dr.Pepper 0 Posted July 14, 2008 Report Share Posted July 14, 2008 Not for me.If I remember rightly, it took a wiggle of the exhaust brackets and mounts to just move it away a tiny bit. Link to post Share on other sites
Karr-Man 0 Posted July 14, 2008 Report Share Posted July 14, 2008 i had a rattle from the heat shield type thing located under the gearstick, managed to get a jubilee clip round the shield and exhaust pipe to hold it in place and its caused me no problems since:) Link to post Share on other sites
hellsVR6 0 Posted July 14, 2008 Author Report Share Posted July 14, 2008 I recently had the same sort of issue but it was my cat converter falling apart!I knew it had issues because when i changed my back box i found chunks of it in there.In the end the exhaust got blocked and the car would not rev over 5000rpm very well' date='so i had to sort it out.Mine used to rattle in the low revs just cruising and pulling away,and some times on start up.Try getting under your car and give the exhaust a good tug about and see if you can hear where the rattle is coming from.[/quote']Thanks, but it better ruddy not be, as I've only had the full system replaced less than 9 mths ago. *-) Link to post Share on other sites
parkersdub 0 Posted July 14, 2008 Report Share Posted July 14, 2008 Just picked my VR up from garage and rattle was down to exhaust being slightly out of alignment. They twisted it a bit and it's now ok. On the downside I need an exhaust soon as it's pretty rotted. Hope this helps Link to post Share on other sites
blackmagicvr 7 Posted July 14, 2008 Report Share Posted July 14, 2008 could be the heat sheild on the bottom of the cat, i had the same on mine at certain revs, get a local garage to put it on the ramp and remove the heat sheild (if it is that!)regards jon. Link to post Share on other sites
