gear linckage splines donald ducked???
Hello
After many many hours scratching my head as to how to remove a threaded nut from my gear linckage (engine bay end-the bit underneath the reverse light sensor) i managed to get it out (after chopping the metal housing to get mole grips in) in the hope a new bolt would nip it up and i could use my gears again.
Things are never that simple!!!
After removing the threaded bolt i find the linckage lever is attached to the box with splines and they are all wrecked. I can select all gears manually by levering the balance weight so it grips the bar that comes out of the box. but obviously i need it to grip on its own.
Has anyone come across this before? Has anyone got any suggestions
Many Thanks
