blackberry 0 Posted May 1, 2008 Report Share Posted May 1, 2008 HiI am looking at another Golf to add to the family (we already have a 96 Vr6 highline). this time its a 3.5 cabbie.there are a couple of electrical gremlins on it ad I wondered if you could help?1 - the front passenger switch does not control the window, it can be from the passenger switch on the driver's door. - is this likely to be the switch that is faulty?2 - Heated seats - the passenger seat won't switch off - what could cause this? - broken switch / relay/sensor?Thanks in advance for your help! Link to post Share on other sites
xyber 1 Posted May 1, 2008 Report Share Posted May 1, 2008 HiI am looking at another Golf to add to the family (we already have a 96 Vr6 highline). this time its a 3.5 cabbie.there are a couple of electrical gremlins on it ad I wondered if you could help?1 - the front passenger switch does not control the window' date=' it can be from the passenger switch on the driver's door. - is this likely to be the switch that is faulty?UNPLUG THE OTHER SWITCH AND PLUG IN ON THE OTHER SIDE AND TRY IT2 - Heated seats - the passenger seat won't switch off - what could cause this? - broken switch / relay/sensor?SOUNDS LIKE A STICKY RELAY OR FAULTY SWITCH, UNPLUG THE CONECTIONS ON THE SWITCH AND COVER WITH INSULATION TAPE UNTIL SORTED OR IF THERE IS A FUSE THAT IS PULLABLE AND WONT AFFECT ANYTHING ELSE YOU NEED, PULL IT Link to post Share on other sites
blackberry 0 Posted May 1, 2008 Author Report Share Posted May 1, 2008 Thanks - will try thsi once I have the car which should hopefully be this weekend! Link to post Share on other sites
