help! foolishly jetwashed my motor now its missfiring
i jet washed the engine bay and now its running like a bag of bolts, its dumping straight fuel into the engine , i,ve taken off all connections and wd 40,d them and blew out any water with an air line , when i remove my tps connectiion it gets better ,when i put it back on it won,t idle , also does anybody know the colour of the tps wires from rear of the car to front on the connector cos mine was crap and i cut it off and put krimps on it instead its just incase i,ve mixed the wires up, i might add thayt at full throttle its not bad but i can feel it retarding the timing any advice please
na stupidly thought it would be ok ,any clues on the sequence of the wires to the tps, i rekon i might have got water in it cos when i unplug it the fault goes away(nearly) i,ve also had the cover off the roker cover and cleaned and sprayed the coil connections with wd40 but to be honest they were dry
