Has anyone had this done? What were the results?
My ABS light has been coming on intermittently for a while, so at my service at Stealth on Monday they changed the rear right sensor as that was what VAGCOM had said (and I also had a bent stub axle which had knackered the sensor ring...but thats a different story)
Anyway, ABS light had come back on. Vince is going to re-solder the ABS ECU joints on Friday as he said rear right ABS sensor fault sometimes points to dry joints in the ECU,
What are my options if the above doesn't work?
