gav_113 0 Posted March 23, 2008 Report Share Posted March 23, 2008 sum of u know i have replaced bottom end wit 2.9 item..is this ok to run wit my ecu? do the 2.9s run a different ecu or chip??thanks.. Link to post Share on other sites
UnitedMotorsport 55 Posted March 23, 2008 Report Share Posted March 23, 2008 It'll run fine, just not make as much power if you have an early OBD1? Link to post Share on other sites
gav_113 0 Posted March 23, 2008 Author Report Share Posted March 23, 2008 thought the raddos were all 0bd1? Link to post Share on other sites
UnitedMotorsport 55 Posted March 23, 2008 Report Share Posted March 23, 2008 EARLY OBD1 as in the 6 pin maf. It is a misconception that all 2.9's are OBD1. Altho all corrados were as far as we know,Which config do you have? coil pack? 6 or 4 pin maf? Link to post Share on other sites
gav_113 0 Posted March 23, 2008 Author Report Share Posted March 23, 2008 ive got dizzy wit 6 pin MAF, BUT theres only 5 connectors on the plug??? whys that?? Link to post Share on other sites
UnitedMotorsport 55 Posted March 23, 2008 Report Share Posted March 23, 2008 I just looked through your engine install pictures and see you have a distrubuter, just as you replied.Unsure on the extra pin, it could be an air temperature output. Link to post Share on other sites
