vortech charger quetsions
please can some body help me iv started fitting my vf engineering charger but cant work out a couple of things
1. do i need to do anything electrics wise other than exted then wires to the air flow meter and the chip
2. were does the vaccum line that comes out of were the oil feed goes into the the charger connect to
3. were abouts does the vaccum line from the bov conect
ill get a pic im the morining but its got like a brass section on it and it goes into the same hole as were the oil feeds into
http://www.vr6oc.com/e107_plugins/coppermine_menu/albums/userpics/14596/Supercharger%20resize.jpg
there is another vaccum line port on the compressor housing of the chager on the section just before the air leaves the charger what is that for
thanks for the help sparkz your a life saver
ok iv found a pic iv put some arows on can any one tell me if im right or wrong
blue arrow oil feed
red is the vaccum line coming from the copresor section of the charger around and into the port were the oil feed enters (blue arrow)
They are all oil lines, the line in goes to the blue block, which has a valve inside it and then runs acroos to the oppsite side if the charger like in the pic
with the vacuum line for the bov, i hooked mine onto the brake booster line on the right hand side of the engine, it has a green cap on a port that is not used, just took the cap off and connected it
