alex1985blue 0 Posted February 26, 2008 Report Share Posted February 26, 2008 Hi All,I want to take of my VR6 and Golf badge on my cra, but I was wandering if they are just stuck on or are they screwed on?Kind regards,Alex Link to post Share on other sites
xyber 1 Posted February 26, 2008 Report Share Posted February 26, 2008 Just tape, but its really tough stuff, get a plastic filler spreader and try and heat it up abit 1st, then just go really carefully and as flat and paralel to the panel as possible and give the whole area a good clean before aswell to get rid of all the grit possible, then just use tar and glue remover to get the residue off Link to post Share on other sites
Damo 85 0 Posted February 27, 2008 Report Share Posted February 27, 2008 I used a thick bit of cotten threaded behind the badges and just "cheesewired" it off. it leaves a fair bit of the adhesive sponge behind but that can be picked off or gently washed off with some car shampoo and hot water etc Link to post Share on other sites
alex1985blue 0 Posted February 27, 2008 Author Report Share Posted February 27, 2008 Ok cool Guys,Cheers for that Think I will be taking it off this weekend.CheersAlex Link to post Share on other sites
sticks 0 Posted February 27, 2008 Report Share Posted February 27, 2008 use some lighter petrol ,(the stuff you fill zippo type lighters up with),spray it on the sticky pads as petrol eats the adesive so will come off niceand easy,put some on let it soak 30 secs to a min have a go at wiping it if not repeat as before until job done,this is also good for taking off stickers ,graphics,sign writing etc off of anything not just cars, tip of the day Link to post Share on other sites
