Sharan 0 Posted January 31, 2008 Report Share Posted January 31, 2008 Hi all. For a long time now I have had a problem with my remote locking/unlocking key not working. I do the 'turn the key threetimes to the right, holding for half a second between each turn, remove the key (light on in door panel), while holding the 'lock' button down, pressing the 'unlock' button three times while pointing at the internal mirror (while holding your nose! - I added that bit!!), Sometimes the door light will flash, indicating that the key has been reprogammed. Sometimes it doesn't. Both times, the key doesn't work. I've changed the batteries in the key (C32's I think) a number of times but no improvemnt. I'm sure it's the key and not the sensors. When you open up the key, ther is a small black plastic 'box' under a metal strip. The box is loose. Not sure if that is right?? Anybody else had a similar experience and been able to solve it?Cheers. Link to post Share on other sites
