Flat Battery after 5 days and oddometer flashing please help
Ok, went to start the car this morning.........flat..........not entirley flat, just flat enough for it not to turn over. Had the car battery checked last week and was told ok
i did notice the oddometer the numbers for the mileage flashes and goes blank off and on and then when the cars running and started the oddometer is fine and goes back to normal
now how long should a cars battery last without daily use?
do u think i have a drain or a short or is it a Alternator problem or do i just need a new battery
please please help and advice!
The alarm (if you have one) will drain alittle power. Mine still started after been off the road for about a month....
If you get it started give it some revs to get the alternator charging and put a muit meter arcross the battery it should read 13-14 volts, If it doesn't your reg or alternator is gone
Tom
