s3 Rich 0 Posted December 19, 2007 Report Share Posted December 19, 2007 Hello anyone,OBD1 seems to be hesitant sometimes when at full chat, not always but most of the time, from 2500rpm upwards.Not got an induction kit yet, cant see the point if I cant get it running smoothly first but it does have the replacement K&N insert.Is there anything on the throttle body I can take off & clean, like speed idle valve or similar?Since owning I have replaced the fuel filter, also plugs & leads as when damp was misfiring a tiny bit.Any help appreciated,Richard Link to post Share on other sites
kalv 0 Posted December 19, 2007 Report Share Posted December 19, 2007 i think u can give the throttle body a clean with some carb cleaner... give that a bash... Link to post Share on other sites
james4287 1 Posted December 19, 2007 Report Share Posted December 19, 2007 http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?185177read that, is thats what happening? Link to post Share on other sites
s3 Rich 0 Posted December 21, 2007 Author Report Share Posted December 21, 2007 no, not the same as the other thread, nowhere near as bad!!someone did mention a possible faulty cat - 13 years old so may be on its way out? they recommended getting a de-cat pipe to use between mot's, but thats obviously illegal!!I have tried injector cleaner & am going to try a good dose of ultimate laced with valve stem seal lubricant (octane booster). That worked well a couple of years ago in the TVR, seemed to clean everything in the fuel side of things.If the cat was removed, would the mapping be ok still? Link to post Share on other sites
gregk9 0 Posted April 23, 2008 Report Share Posted April 23, 2008 If you did remove the cat, the ecu will still adjust the fuel/air mix to maintain correct signal from the lambda sensor.the only way of actually seeing that there is "more" comming out of the exhaust than there should be is by doing a "4 gas" check on a exhaust gas analyser.but you would be surprised how well the system still works without a cat in situ.Of course the only guys who "could" get nervous over the removal of the cat is the vehicle inspectorate on a roadside check, but that is only a rectification notice and a refitting jobbie if ness. Link to post Share on other sites
