how do u tell if clutch is on the way out( high biting point)plesea help and advice
Mine started doing that about 3 months ago. The biting piont feels like it's about 1cm away from the top end, i was worried and thought i should get the clutch replaced but i didn't have the monies on me. It's been fine for 3 months but it has just started to slip every now and then. I know the standard clutch is a good one, but would a performance clutch last longer?
Wait till it starts slipping then take it somwhere. You can check the guides by removing the timing covers and just checking them for wear.
If your putting a new clutch in its probaly the first one its had fitted. They can last for well over 100,000 miles, I donno if performace once last longer but standard ones are ment to be good for 250bhp
Mine started doing that about 3 months ago. The biting piont feels like it's about 1cm away from the top end' date=' i was worried and thought i should get the clutch replaced but i didn't have the monies on me. It's been fine for 3 months but it has just started to slip every now and then. I know the standard clutch is a good one, but would a performance clutch last longer?
cowpatt
how much was th vag std clutch ?????
did u fit this yourself and did u check the chains and guides at the same time
how were they worn away rattling etc.... or was it all done before u bought the care
hows them coilovers i 99 percent going to get them
what setting 1-6 and how low i dont want to rub and i dont want to wear neck brace
do they settle down after a couple of weeks
sorry for all the questions thanks pete
i brought the clutch for £80 from gsf car parts.
i got someone else to fit it, i was going to do it myself but its been way too cold outside to do it. so i just gave it to a clutch specialist to do it. cost about 200 plust vat to do.
I didnt do the chains because i didnt have the money at the time. i wanted to but i was planning to do it after chrismas when i have more time.
With the coilovers they are still really good!
i had mine set pretty low as you can see in my sig pic, but still could go lower. i have now raised it a bit at to front because the wheel was rubbing on the arches on tight corners, doesnt help having 17" wheels.
setting 1 is the softest and it is really comfy but still hold the road like glue, setting 6 is the hardest and the handling is amazing but on a long journey on motorway can be abit annoying because i found i couldnt sit steady enough to adjust the stereo volume...lol.
It only takes 5 mins max to adjust the setting.
takes about a week or two depend on how much you drive for the springs to settle. good idea to check bolts and stuff are still tight after a week or so. none of mine were loose but always best to be safe rather than sorry.
hope this helps
Matt
