was8v 0 Posted December 5, 2007 Report Share Posted December 5, 2007 I've bought a Corrado 2.9 VR6 running fine. However it has had problems before as there is a dodgy bit of wire connecting the Red/Blue wire from the ECU to the Black wire on the coil.Has anyone got a pinout for the Motronic ECU and the coil?What is the function of that wire at the ECU and the coil? I thought it was perhaps to switch the coil on or to send it a signal?I presume the dodgy bit of wire has been put there because the connection is broken along its normal path. I'd like to find the break or replace the dodgy bit of wire with a neater soldered bit, but would like to know what its for and where it goes first!Cheers. Link to post Share on other sites
was8v 0 Posted December 8, 2007 Author Report Share Posted December 8, 2007 bump Link to post Share on other sites
