gkjnr 0 Posted October 11, 2007 Report Share Posted October 11, 2007 hi guys i,ve just got vr6 obd1 engined mk2 and it has the centre consul with the 3 guages in only the volts one is working i,ve had a look and the other 2 are connected but don,t work when i swapped the wires round the temp one started to work slightly but the oil temp on my clocks was reading low, has anybody got these guages in a mk? any help appreciated cheers Link to post Share on other sites
kilokilla 0 Posted November 22, 2007 Report Share Posted November 22, 2007 the vdo clocks need different sensors to run them you can get a splitter for the oil one so that you have the standard sensor and the one for the vdo coming off the same sensor hole if you get what i mean check that you have something like this fitted to youe engine if not that is why they wont work properly.im sure you can get the relevent parts from big boys toys. Link to post Share on other sites
