dub_weiser 0 Posted August 11, 2004 Report Share Posted August 11, 2004 Hi, how do these get fitted. Got a set of side skirts and am curious how they work.Cheers Link to post Share on other sites
danb 0 Posted August 11, 2004 Report Share Posted August 11, 2004 You need a set of pop rivet pliers which you can buy from most car bars for about a fiver !there dead easy to use just put the rivet stem in the rivet plier nozzle and squeeze the handles together, repeat this until the rivet stem breaks away from the rivet head . Your best off using 3mm thickness rivets that are about 20mm long . Hope this helps ! Link to post Share on other sites
dub_weiser 0 Posted August 11, 2004 Author Report Share Posted August 11, 2004 Cheers that def helps, will check with some local car places about the pliers. Link to post Share on other sites
