adamsimmons 0 Posted September 2, 2007 Report Share Posted September 2, 2007 I have an ODB1 engine with the 6 pin MAF, as i understand these changed over to 4 pin in November 93. I need to change my loom over to the 4 pin connector, I have managed to get hold of the wiring diagram with both maf's on, and it shows that for the 6 pin maf connects to a switch in the engine control relay, and the 4 pin maf connect to a switch in the fuel pump relay.6 Pin MAF1. Earth2. Pin 16 on ECU3. Pin 17 on ECU4. Pin 59 on ECU5. Switch on Engine Control Relay6. No Connection4 Pin MAF1. Earth2. Pin 16 on ECU3. Switch on Fuel Pump Relay4. Pin 17 on ECUTo connect the 4 pin maf to my harness I was thinking that it should be ok to swap a few of the wires so that they correspond with the connection on the 4 pin maf e.g. Pin 1 on 6pin maf goes Pin 1 on 4 pin maf, Pin 2 on 6 pin maf goes to Pin 2 on 4 pin maf, Pin 3 on 6 pin maf goes to pin 4 on 4 pin maf, and pin 5 goes to pin 3. Which then makes pin 4 redundant on 6 pin connector. Do you think if I do this I should then be able to run the 4 pin maf with my ecu. I forgot to mention the reason that I'm doing this is because the maf for the charger is the 4 pin and the standard one is 6 pin.I hope that I haven't made this too confusing, and hoping that someone can clarify my understanding on how this works.Thanks in advance Link to post Share on other sites
adamsimmons 0 Posted September 2, 2007 Author Report Share Posted September 2, 2007 Ive found out pin 59 on the ecu is for filament burn off, and as I understand that the 4 pin maf does not have a filament so that it doesn't require this. Am I correct? Link to post Share on other sites
Goldie 0 Posted September 2, 2007 Report Share Posted September 2, 2007 the 4 pin maf wont work on a 6 pin maf ecu. Link to post Share on other sites
adamsimmons 0 Posted September 2, 2007 Author Report Share Posted September 2, 2007 Do you know why not as the pins are there and as far as I can see all the OBD1 ecu are the same until they changed over to the OBD2. I can see on the wiring diagram for the ecu pin 59 is still there it's just not used. So if I wire the 4 pin exactly the same as that later model, I can't see why it wouldnt work. Could you explain why it won't work and if there is a work around. Cheers again Link to post Share on other sites
agolebio 0 Posted March 26, 2012 Report Share Posted March 26, 2012 Hi Did you manage to wire a 4pin MAF for you original stock ECU, how was it running? Link to post Share on other sites
UnitedMotorsport 55 Posted March 27, 2012 Report Share Posted March 27, 2012 I can't see why it wouldnt work. Could you explain why it won't work and if there is a work around.Because the electrical characteristics of the 2 MAF;s are different Link to post Share on other sites
