ThermalP4 1 Posted August 18, 2007 Report Share Posted August 18, 2007 Hi guys.I've got a 1995 OBD1 VR and cant find the Coolant system drain plug?I've contemplated taking the bottom rad hose off but would rather use the drain plug.Does anyone know where it is? Cant find it at all! Link to post Share on other sites
xyber 1 Posted August 18, 2007 Report Share Posted August 18, 2007 its in the plastic pipe that runs along under the inlet mani to the thermostat housing with the 3 multiplugs on it, but i couldnt spot it either so just did the hose off the rad route, the plug and O-ring needs from the coolant drain replacing if you do take it outalso take the coolant reservior cap off and the heater temp control to full hot when draining Link to post Share on other sites
ThermalP4 1 Posted August 18, 2007 Author Report Share Posted August 18, 2007 Ah right.Did have a look there but couldnt spot it.I'll go the rad hose route instead i think.Those clips are a pain to get off/on though!All fun i suupose.Cheers mate. Link to post Share on other sites
4mobora 0 Posted August 18, 2007 Report Share Posted August 18, 2007 dont forget to flush with a hose through the rad the header tank, and top and bottom rad hose Link to post Share on other sites
