vr6pumba 0 Posted August 13, 2007 Report Share Posted August 13, 2007 my brake pad warning light is on even after i changed the pads does anyone have a clue what it could be Link to post Share on other sites
spanky 0 Posted August 14, 2007 Report Share Posted August 14, 2007 Get a code reader/ VAGcom on it to read any codes. Link to post Share on other sites
Ben Seabrook 4 Posted August 14, 2007 Report Share Posted August 14, 2007 I have the same problem mate had them all checked and nothing wrong and put it on VAGcom and nothing came up !!!! Link to post Share on other sites
xyber 1 Posted August 14, 2007 Report Share Posted August 14, 2007 I had a chaffed cable that caused that intermittantly Link to post Share on other sites
Ben Seabrook 4 Posted August 14, 2007 Report Share Posted August 14, 2007 my light stays on all the time and two useless garages have found nothing wrong !!!! Link to post Share on other sites
xyber 1 Posted August 14, 2007 Report Share Posted August 14, 2007 Mine stayed on in the wet when the chaffed cable got wet, when it was dry it was fine Link to post Share on other sites
Ben Seabrook 4 Posted August 14, 2007 Report Share Posted August 14, 2007 oh well looks like i will have to get some help get under the car and have a look about :S Link to post Share on other sites
H19LNE 0 Posted August 14, 2007 Report Share Posted August 14, 2007 Could be needin Brake Fluid ??? Link to post Share on other sites
rodney 17 Posted August 15, 2007 Report Share Posted August 15, 2007 the light comes on for a couple or three reasons. The cap on the resevoir thing may have popped off when being re-fitted, the wires as mnetioned above and there is a little relay on the back of the handbrake. Thats it as far as I'm aware... Hope it helps Link to post Share on other sites
Ben Seabrook 4 Posted August 15, 2007 Report Share Posted August 15, 2007 and there is a little relay on the back of the handbrake. whats this bit mate and is it easy to get too ??? save me having to get under the car and check all the wires !! Link to post Share on other sites
bear 0 Posted August 15, 2007 Report Share Posted August 15, 2007 i have the same problem,had the drivers seat out to check the wire from the handbrake to the fuse box,looked ok,auto electrician said it might be behind the dash,£120 to fix.or if i take the dash out £40 Link to post Share on other sites
