Increased Idle - Sticky Throttle?
Hi
I've got an OBD2 golf highline and have come up with a problem. Initially the car bogged down when warmed up. I cleaned the throttle body last night, foudn some loose clamp on the air box tubing and two loose plugs. The plugs were PCV heater by the MAF which was on back to front, and the ECT plug was loose too.
Now it starts fine, but has a higher idle and takes a bit of time to settle down. This is not just on start up but also whenever moving into neutral, changing gear etc.
Any ideas on what to look for?
Thanks
Paul
After I cleaned my throttle body, the car was idling very high too. I made sure I sprayed loads of carb cleaner into the inlet manifold etc. It settled down after running/driving for 2-3 hours. You have to give the ECU time to re-adjust as it was probably originally compensating for the restricted air flow through your dirty TB.
