Ben Seabrook 4 Posted July 11, 2007 Report Share Posted July 11, 2007 Will these alloys fit my car :-Rim Width: 7.5J Tyre Width: 225Rim Diameter: 17 inches Aspect Ratio: 45Offset: 30 Load Index: 91Number of Studs: 5 Speed Rating: Y: max 186 mphStud Diameter: 112 Tyre Manufacturer: Goodyearand if they won't is there anyway to get them too *-) ThanksBen Link to post Share on other sites
VR6Rob 0 Posted July 11, 2007 Report Share Posted July 11, 2007 the stud diameter is 112 where the vr is 100 you could use adaptors but the will be 20mm bringing the offset to 10 making them stick out to fardepending on the center of the wheel you might be able to redrill them to 100pcd but could affect the strength of the wheel but would go straight on Link to post Share on other sites
craggsy 91 Posted July 11, 2007 Report Share Posted July 11, 2007 Itsquite possible...but the tyres will be a big no no. You will need 205/40 17s at least maybe 195/40 for clearance issues.Don't redrill em as it can weaken the wheel.The stud diameter is either Audi or Merc depends on the diameter of centre bore.There are manufacturers who make 15mm adapters but they are custom jobbies so as Rob says 20mm is best bet Link to post Share on other sites
Ben Seabrook 4 Posted July 11, 2007 Author Report Share Posted July 11, 2007 Oh well was just trying to be a cheapskate and save a few quid but doesn't sound worth it so will buy the proper ones and spend the extra Probably the best thing to do anyway !!!but thanks for your advice fellas Link to post Share on other sites
