amazak 3 Posted July 6, 2007 Report Share Posted July 6, 2007 Hello,Will all mk3 golf (Gti, Tdi, CL) lowering kits fit a vr6? Someone said that it will not fit because the engine is larger hence Vr6's use different front springs? If that were to be correct then it is possible to use the same dampers and change the lowering springs for one's that are specifically manufactured for Vr6's??, furthermore do the rears need different springs as well??Thanks Link to post Share on other sites
VR6BOY 2 Posted July 6, 2007 Report Share Posted July 6, 2007 The VR6 engine is a lot heavier than them little 4 bangers so while they will phsically fit they wont last to long better to hold of and getting the proper set for your car Link to post Share on other sites
amazak 3 Posted July 6, 2007 Author Report Share Posted July 6, 2007 Thanks for the reply, are you referring to the entire kit or just the springs itself?Thanks Link to post Share on other sites
VR6BOY 2 Posted July 6, 2007 Report Share Posted July 6, 2007 If it was me i would Stick with the whole kit designed for your car Link to post Share on other sites
amazak 3 Posted July 6, 2007 Author Report Share Posted July 6, 2007 Cool! , trying to save a few quid as the used Vr lowering kits are hard to come by.Thanks Link to post Share on other sites
VR6BOY 2 Posted July 6, 2007 Report Share Posted July 6, 2007 keep an eye out they come up from time to time keep an eye on the classified section Link to post Share on other sites
