[moved] supercharged vr6 oil
Answered my own question in the end whilst looking for something completly different! Thought id post it up as It was quite useful
What type of maintenance is required with a Vortech supercharger system?
Follow the vehicle owners' manual recommendations for your vehicle. We do ask that you change your engine oil at regular intervals because the engine oil cools and lubricates the supercharger gears and bearings. When changing your oil, remove and clean the oil inlet fitting and strainer. For severe duty or racing, it is suggested that you install an oil cooler and filter. We suggest following the manufacturers recommendations concerning oil type and oil change interval. You can use mineral based, synthetic blend, or full synthetic oils with a Vortech supercharger system as long as the oil meets or exceeds vehicle manufacturer recommendations.
plus some interesting bits in the link below
http://www.vortechsuperchargers.com/pdf/guides/streetfile.pdf
