Hi All I have got a real electrical problem with my indicater lights. For some reason all of the right hand side indicater lights are staying on when the keys are out of the ignition. the turning light stays on in the dash aswell even though the indicater is central. I found that If I disconect the rear left hand side loom from the circuit board the lights go out.I have replaced both circuits boards and looms and still get the same problem. Also if I press the idicater stalk down I get that tizing noise telling you have left the idicater down, if I push it up i don't get the noise. So does anyone think that the stalk has gone or the relay. It stils clicks when I move the stalk up or down. After all this I have now disconected the rear lights so the lights go off. Then when using the alarm the lights flash at the front as they should . Please guys anyone help me.I have taken the car off the road for this reason. :@
My MK3 has a got a serious back light fault.The story is that the rear right lights burn out as soon as I put in new bulbs in but only on the right and start smoking (white). I did'nt use the car for 2 weeks and went to go in and found the battery was dead. I recharged it and as soon as I connected the battery, i found that the indicators on the right were were staying on and not flashing.The indicator stalk was central, so I checked all light connections and found that if I disconnected the rear left the lights went out. So I though t easy, new looms and wires and circuit boards. Did both sides and still got problem. Thought the rely may have gone so changed that and still got the same dam problem. I am in desperate need of help guys,how can I chase the fault. One of the fuses had burnt out for the indicators but replaced that and its not blowing. Please help otherwise its being towed next week to electrical shop.
air bag is easy to take off just two allen key bolt goin in through the wheel in to it undo them and removunplug air bag wiring, undo the big bolt that holda the steerin wheel on make sure u mark it b4 u take it off othere wish it will bee wonky when u put it back on and then just the trims arpund the clounm a couple of screws as i remember then the slip ring and then it ther ein fornt of u mite be a couple of screws holing it in cant remeber
oh and whenu have the airbag off dont turn the ingintion on as it will put the waring ligh on
good luck mate
