Engine electrical diagrams
I aquired a Chiltons manual for my Vr6 and having worked out that the Lambda probe wasnt working i decided to take a look. Low and behold lots of chopped out bits of wire and connecters had been added. I started to read the manual and decided the best way was to rewire the hole thing, the manual witters on about VR^6 golfs only having the Motronic system yet the manual only gives you wiring diagrams for the digifant system. Does any one know where i can get hold of the correct wiring diagram pref. from the tinternet. Iv had alot of troble with this car and its obviously at some point had a transplanted engine and many other fantastic bodges done to it. The car was hesitating when you accelerated so looking at the lamda probe was a good start im now driving round with it disconected and nothing has changed leading me to belive that this is one if not the main problem. If it aint measuring the emmisions then i cant be setting the correct fuel mixture etc. Any replys would most wellcome
Ben (homer) Hobson
ben.hobson1@tesco.net
