whine/funny grinding noise
you are talking about the auxillary belt tensioner, you might not need a new one, take it off and relube the bearing, you can prise the side of the bearing off and pack it with some decent grease. If its completely knackered they dont cost that much from vw mate, the whole unit that is. or if you get the dimensions of the bearing i found this site that does just about every bearing you can think of, you could give them a try.
http://www.bearings2you.com/products.htm
