about to do chains, and swap 'boxes...anything i haven't thought of?
...parts wise.
i've got all the chains parts, more fluid for the gearbox (MT90 :) ), and new mounts will be bought shortly.
anything else? any bolts i need to replace on refitting stuff (flywheel/clutch)?
i'll be checking the condition of the clutch, and then decide whether to change it.
also, theres a bush in the top of the gearbox (looks identical to a rear wishbone bush!), presum its where the shift linkage goes in? can this be replaced, as the one on the new 'box looks pretty worn.
[ Edited ]
acf if your gonna get the box out then get the flywheel done too, as it makes the car rev more responsively through the gears especially at low gears. but make sure its lightweight in order to see the difference!! Ridgeway racing do one, they are based in iver.
i'll try and dig up the website.
