Luke 0 Posted October 15, 2006 Report Share Posted October 15, 2006 Maybe im bein stupid here but wot the f**k is a Carbon canister & wot does it do *-) Link to post Share on other sites
binliner 0 Posted October 15, 2006 Report Share Posted October 15, 2006 It's a black cylinder with 2 hoses on the top of it (you can see the top of it in front of your airbox)It basically filters the fumes that vent from the fuel tank and recirculates into the inlet manifold Link to post Share on other sites
Luke 0 Posted October 15, 2006 Author Report Share Posted October 15, 2006 It's a black cylinder with 2 hoses on the top of it (you can see the top of it in front of your airbox)It basically filters the fumes that vent from the fuel tank and recirculates into the inlet manifold ahhh... Can i remove it wiv no adverse affects 2 my car as i want 2 run a cold airfeed pipe around that area? only ask this as ive herd of people removin them wen chargin 4 room etc... mine is still n/a does this matter? *-) Link to post Share on other sites
mk3anni 0 Posted October 15, 2006 Report Share Posted October 15, 2006 Yeah you can remove it. It only works for the first few years anyway.Leave the valve plugged in, block off the black pipe, I used a screw, and run the clear pipe down to the wing behind the plastic arch liner so the vapours vent to atmosphere. Link to post Share on other sites
antera309 3 Posted October 16, 2006 Report Share Posted October 16, 2006 Already being discussed here: http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?140174 Link to post Share on other sites
