converting air con to climate control
Hi Andy.
I would stick with your air-con m8. Climate control is excellent when its working ok but you will need to do a lot of work to fit it to a car, even with air con. There is a seperate climate control unit which would need to be fitted. The dash will almost certainly need to come out to fit this to your existing air con system. Anything is possible but I'm sure it will be more of a headache to install than it is worth in the end.
Kevin
