Phylo99
About Phylo99
    Sittingbourne, Kent UK
  1. Thanks have you had any experience with this problem? Where are they located
  2. Hi did you resolve this issue? I have same problem with my 97 vr6 I’ve had new keys and chips and the thatcham alarm stripped out professional and it’s srill doing it please help
  3. Hi thanks for the message will any garage computer diagnostics show the fault codes or does it have to be a Vagcom tester? Best regards Phil
  4. Hi Im Philip I have a P reg VR6 Highline all original in Black owned for 2 years - Its been off the road for a year waiting for me to get around to a huge list of work it failed an MOT on to get back on the road First job I wanted to tackle is the combined no ABS / Airbag light working on ignition key turn or start up .. I took the dashboard light out and it was not connected at the rear and thought great ! plug it in it will work .. No not the case .. I tested the two bulbs they have a circuit so they are not broken .. the brakes all work fine having new pads, discs all round and the ABS w
  5. Hi Im Philip I have a P reg VR6 Highline all original in Black owned for 2 years - Its been off the road for a year waiting for me to get around to a huge list of work it failed an MOT on to get back on the road First job I wanted to tackle is the combined no ABS / Airbag light working on ignition key turn or start up .. I took the dashboard light out and it was not connected at the rear and thought great ! plug it in it will work .. No not the case .. I tested the two bulbs they have a circuit so they are not broken .. the brakes all work fine having new pads, discs all round and the ABS w
