bleakerz15
Everything posted by bleakerz15
  1. Ok thanks will give it ago saturday morning. Going to change coolant sensor also. Just hope it's not leads or coilpack making it run bad, looked at the coilpack this everning could not see any cracks. Will remove it sat and have a good look also strip throttle body and give it a good clean. All plugs changed they all looked ok
  2. The sensor I removed was like that one, the new one I had from vw was plastic. But does not seem to fit as there is a rubber on the sensor and one in the engine recess.
  3. My vr has been over fuelling lately running rich and lumpy. Plugged into vagcom and it come up error code for crank sensor. So ordered one using my number plate number. Had a few problems with parts for my car as it's a 95 plate everything is obd1 apart from the obd2 16pin plug so I think it was built half way though the change. I removed the sensor too find a metal sensor with the oring in a recess in the block, the new plastic sensor has an oring on the plastic and does not seem too fit. Anyone had this problem, Thanks in advance
