Content Type
VR6OC News
Website Content
Profiles
Forums
Calendar
Gallery
Store
Collections
Community Map
Posts posted by mk2vr6
The connectors in yellow circles are the same, as I mentioned signal for IAT on pin36 on ecu plug is going on this black sensor on flange. I'm sure it cannot be that factory, someone played with the wiring for sure...
Some people are using IAT from mk4 1.8t to get a few 'horses' becouse of his abillity to measure quick changes of intake air temp a lot better than factory IAT which needs some period to cool down or to heat up. If i'm using this flange sensor instead IAT it would give informations of water temp, not about intake air temp and I'm sure I'll got less power on that way. It would give informations about hot air all the time, and the car for sure won't run as it should... That's my opinion.
Yeah mate, compeletely the same connectors... totaly weird.
Yes it is... And I haven't mentioned that the sensor on flange is bad, so replacing it should delete the code. But I'm not sure is it clever to use this connector and connect it to iat sensor becouse connectors are the same...
Thanks a lot guys...
@Lukey zoom a pic and you will figure it out, it's pretty simple, just change them places and go from up to down on every next one.
I`ve got an bad IAT sensor code on my diagnostic.
I have no wiring for this sensor on my `92 OBD1 vr6, I found that the signal for IAT is on pin36 on ecu plug.
The problem is this wire from the ecu is going to the 3rd black (2pin) flange sensor. Now I wonder if it`s factory that this sensor replaces IAT or what, it should be AC sensor as I know. But my car is non AC.
Hello guys, i'm glad to present you my project. I had an mk2 with 1,6l engine, which is now completely restored and vr6 powered... first stage look
second stage
and then stripping and preparing for engine
got the engine
got a set of BBS RS016 15'' which I streched with new lips 1,5'' and 2'' on the rear
prepared it for paint
car painted and engine got inside
did some work on my rims
i had spun the rod bearings and got this
pulled engine out and started collecting parts
ported and polished intake and head
new clutch
mk4 head gasket
engine in, by the way painted the bay and got the exhaust manifold
car is now running fine and a few things left to do
some pics from photoshoot
and for the end a short movie
Fuel pump wiring
in Engine Maintenance and Problems
Posted
It could be damaged fuel pump wiring or bad connection on fuse box, check all connections and fuses.
On fuel pump connector you have: red yellow (+12v for fuel pump)
purple black (signal for fuel level)
blue brown (signal ground)
brown (fuel pump ground)
