willz94
Everything posted by willz94
  1. almost certain my ecu is fried im just wondering if could also be causing the following: Central locking failure Electric window failure Electric sunroof failure oil pressure light flashing No spark Thanks in advance for the help
  2. almost certain my ecu is fried im just wondering if could also be causing the following: Central locking failure Electric window failure Electric sunroof failure oil pressure light flashing No spark Thanks in advance for the help
  3. ive tried the battery ecu soft reset and had no luck, but im going back up the garage later so ill check for any snapped or incorrectly connected wires and let you know how i got on , and im sure theres a multimeter up the garage thanks for the reply
  4. Problem 1: not the easiest problem to explain but I shall have ago: when the battery is disconnected the drivers side door can lock and unlock as normal and door will open and close. once I reconnect the battery and lock the door the door deadlocks, i turn the key and the door pin will rise but the door still will not open. i disconnect the battery and the problem is gone very confused. only for the drivers side door. I was told it could be due to the Gemini alarm present on the car, I have removed the alarm completely and the problem is still there. Problem 2: car needed a new battery, i re
