Problem 1: not the easiest problem to explain but I shall have ago: when the battery is disconnected the drivers side door can lock and unlock as normal and door will open and close. once I reconnect the battery and lock the door the door deadlocks, i turn the key and the door pin will rise but the door still will not open. i disconnect the battery and the problem is gone very confused. only for the drivers side door. I was told it could be due to the Gemini alarm present on the car, I have removed the alarm completely and the problem is still there. Problem 2: car needed a new battery, i re
