Dizzy
Everything posted by Dizzy
  1. No1 local that I no of that has vr got AA out but Thay not got the rite plug to test it he only got 16 pin , but he reckons it maf so do I take gamble and spend the £65 on new maf
  2. It did rev better wiv airfilter out and maf sensor connected but not enough to drive it
  3. Unfortunately no,iv just took air filter out and run without and it run better
  4. No need to feel daft fella' date=' everyone here to help.. Look at the engine, right side of block below inlet, you will either see 2 or 3 colours, Yellow Brown and Blue, if your car has no A/C then its only 2 colours, think its Brown and Blue, Disconnect the blue, start car and see what the outcome is, does it make things worse, or same?? [/quote']
  5. Hi feel a bit daft but we're the coolant temp switch thanks
  6. Hi iv disconnected maf and it made no difference weather it should of and that says there something wrong with it I'm not sure thanks
  7. Hi my vr6 will now start but wen rev it up it lumpy and splutery which it won't even pull of with it, î
  8. Plugs and leads r new dizzy looks new.it ticks of perfect just revs up lumpy and splutery just wondering if there any were specific that water gets in on to sum electrics but all looks dryî
  9. hi there fuel geting to the fuel rail wen turned over fuel came thru pipe but it also shot out of fuel rail end it started but wont rev up well does but ruff
  10. Hi guys bought new maf sensor and car runs great now, so THANKS guys for all ur help îŸ
  11. hi guys me again what engine oil would u recomend to put in thanks dizzy also do they have problems when heavy rain as mine kept dyeing on me today and had horrible smell thanks
