Baz
About Baz
    Gosport
  1. Evening all, I'm hopefully about to get a set of 17" Toora T970's for my black 3 door VR6. They need refurbing And I'm thinking of going for an anthracite finish ? What do you lot think ? Any pics that might help would be greatly appreciated. Baz
  2. Just got the lights sorted out. It turned out to be the light bulb board, I replaced that & put new bulbs in & now all is fine. Cheers for your help guys. Baz
  3. What would be the common place to look ?
  4. Hi everyone, My interior light has started to come on when the door is closed, the smaller map light next to it flickers & now the rear indicators & rear fog light come on when I press the brake pedal instead of the brake lights ! Has anyone else had this, is there a module that controls the lights ? Thanks for any help. Baz
  5. Morning, Can anyone tell me how to get to the bolt so that I can remove the charcoal canister to fit a cold air feed for my VR ? Cheers Baz
  6. Morning all, Does anyone know of a 6 speed box that would fit relatively easy into my 97 VR6 ? I think that one out of a Sharan might fit but I'm not sure ? Cheers Baz
  7. I'm thinking of getting a Superchip for my VR as I want it a bit smoother & bit more power. are they any good ?
  8. Hi, I've got a rumbling noise which I can also feel through the clutch pedal. It doesn't go away if I press the clutch which I assume would rule out the thrust bearing. It's also slower to turn over & doesn't feel as sprightly as it did a few days ago. Any ideas ? Cheers for any help Baz
  9. I've had a look online & I can't find any Brembo discs that are 288mm only the earlier 280mm ones, I'm thinking of going for some Tarox G88 discs & Strada pads all round.
  10. Hi, I'm getting quite bad brake judder so I'm going to replace my front discs. What are the best upgraded discs to go for ? I have seen some tarox ones that look good, also I believe mine are 288mm diameter, what thickness would they be 25mm ? Baz
  11. Hi, Has Anyone used 15W-50 oil in their engine here ? I only ask as mine needs an oil change and I've got 5 litres of Silkolene Pro R 15W-50 that I was going to use on my Skyline & wondered if it would be any good ? Baz
  12. Hi everyone, I've just bought a glove box to replace the airbag but before I swap them over I just want to check which resistor I'll need to stop the light from coming on, I read somewhere that it's a 2.7 Ohm 0.5 Watt 5% does this sound about right ? Baz
  13. Baz
    Glove Box
    Hi Would it be possible to replace my passenger side airbag with a glove box ? I only ask as the lower glove box on my 97 highline has hardly any room in it, where as the upper one's have loads. Baz
  14. Has anyone here used Lamin-x for their headlights & if so was it east to put on ? Baz
