Jonny_1983
About Jonny_1983
    Greenock
  1. cheers mate that would be great. It should be one big lead with the battery terminal still connected to it.
  2. Hi guys wanted to post this in the wanted section but cant yet. when i was cleaning my engine bay my lead snapped where it is bolted to the chassis just underneath the coolant bottle So if somebody knows where i can source one can they please let my know asap. The car will run if jumped but when switched off the battery just dies on me.
  3. went out to the car this morning to have a look at the car. The only thing i noticed was that even though the 13mm bolt that connects the linkage to the box is tight but there is still movement in the bit it tightens up onto. you can move this bit up and down and angle it. If you look at the bolt there is a bout a 2mm gap between its base and the base of the linkage.
  4. Hi guys, After doing a bit of cleaning under the bonnet i found that it is a bit difficuilt to get the car into 1st and 5th gear at times. I never touched any thing underthere, just a quick degrease and polish of paint and stuff. Cheers for any help.
