engineerrupert
Everything posted by engineerrupert
  1. Mate I did one recently but do not forget if you have air con then you will have to break the circuit as well and there are some hidden bolts on the engine side of the firewall as well. Hope this is of some help to you.
  2. Hi I have just converted my 1997 Vento VR6 from Auto to Manual and need to know if someone can tell me if the reverse lights run off the same circuits and/or through the auto ECU and if so which wires I need to link together to get them to work?
  3. Well having just read this, I have recently done the conversion from auto to manual on my 1997 Vento VR6. The easiest way of getting the gearbox out is to drop the subframe complete with the engine and box, or support them bothand take the frame out by itsself, it is also worth poly busing it whilst the frame is out and you have good access to it. I am now on a mission to get my reverse lights to work. Also when doing the conversion you will need to know which wires to link to get the car to think it is in park or neutral to get it to start. To change the pedal box, I removed my dash as I was
