sharma187
About sharma187
london
How's it going guys. Got to the bottom of the situation. Friend left his car with me so I checked timing and it was out! Thanks audimk312v! Looks like oil pump failed so obviously the timing chain tensioner was no longer being fed with oil causing chains to go slack and jump. In the end cylinder 2 intake valve was bent ever so slightly and the valve spring broke. Had the head skimmed and put it back together now she runs like a dream. Thanks for help anyway guys. Just goes to show with a little investigation i managed to save him a few.
Anyone know where I will be able to source a reliable second hand lump?
A guy I know does v dubs strictly. Rebuild was done over a year ago. motor is hardly driven.
Yep timing is spot on.
Hmm...worst thing is it's just been rebuilt less than 1k miles ago !
Ok thanks will try that. I'm just a little confused as to how it would be possible for valve damage to occur. Any thoughts?
sharma187 reacted to a post in a topic: Oil Pump push rod snapped
hi guys wonder if i could get come help here. was driving along in the mk3vr6 as you do when all of a sudden it started misfiring. got to a set of traffic lights and the engine started to sound very tapety like low oil, i then drove home as i was like 2 minutes away and the red oil light comes on... turns out the rod that drives the pump snapped. Ive replaced the pump and shaft but for some reason its still missing. wait for it... i checked spark and fuel all was fine and dandy, checked compression all was good however… number 2 cylinder has zero compression…I'm struggling to under
Woah that's allot. Even on the most very basic of stage setup. Is it worth buying one second hand if so how much should I realsiticly expect to pay?? Are their any other cheaper ways of getting more power output. Only reason I say is because I had a mk2 vr6 and that was really fast. I don't get the same feeling in this mk3.
Hey people I just wanted to know when supercharging my vr6 how much would I be looking to spend on parts only. Thanks.
Drill it out and then nut and bolt it.
After a 100k
Changed plugs and leads and now it's ok. Thank god it's all over. The joys of owning a VR6. Drives sweet now a friend of mine recommended rebuilding the engine because he reckons these engines are nackered
occasional misfire and backfire
sharma187 replied to Dragon Dave's topic in Engine Maintenance and Problems
I have same problem -
Today I checked codes and checked all breather pipes were ok and every thing was fine. A few codes came up but nothing corresponding to the misfire issue. Tommorow I will take the rocker cover off and check the timing. What symptoms would I get if the timing was off ??
Cheer pal will try that. I'm going to put a diagnostic tool on it and I noticed it misses in every gear between 1 - 2 k revs then it clears up and I'm getting around 8 - 12 mpg before I was getting 24 lol
