Paulturnervr6
About Paulturnervr6
    Kings lynn
  1. hi had the car plugged in today to find out what is causing my vr to idle at around 1800rpm and the only thing that we could find using VAG is it saying that the ambient outside temperature is -49 with only the ignition on but when the engine is running then it jumps up to the correct temperature that the engine is running at?? could this cause itt to rev high?? where can i get the 2 yellow and blue sensors from??
  2. hi im wondering if anyone can help me? i recently changed the leads and plugs on my vr and cleaned out all the breather pipes and throttle bodie due to it hunting a little! since then everytime i start it it revs up to 2 thousand revs on idle and stays there. i have changed the air idle control valve cos thats what the garage said was wrong and it still does the same? if you unplug the AIC then it idles ok but runs like a sack of sh*t! tried unplugging the MAF sensor and that does nothing, checked all the air pipes for a leak but everything seems to be in order there. im seriously starting to
