edalices
About edalices
    Nova Scotia
  1. Thanks guys After MAF, cat, filters and wires It was the screen on bottom of airbox scuzzed out, probably undercoating residue and everything else, even saw mouse debris up against it from the outside!
  2. Thanks guys can you explain how "check the reading to see if there is an open circuit"? Am I checking each pin at car's MAF connector to ground looking for some continuity on most or all wires? Ignition off OK? Thanks, Ed
  3. Hi all, I am running about 50-60% power right now, car has a good head. Power loss was fairly sudden symptom. Just sounds flat, actually fairly smooth, just no power, pretty difficult taking off, etc, occasionally seems to "float" a little better power for a couple seconds at a time. fuel consumption showing 50% higher than normal (15-16L/100km instead of 10-11L/100km) In past week I have: changed air&fuel filters looked VERY hard for vac leaks and broken wires swapped MAF with "known good one" from eBay (don't suspect it because absolutely no change to symptom) changed cat converter c
