Everything posted by theboffin
hi just got spliter ..nice quality, but due to a change of plans i'm selling my highline, so this is now up for sale..£30 inc postage if you want it? plmk cheers
i'm waiting for one from eurowagens..i'll let you know the quality when it get it!
hi refurbing my chipped wooden highline gearknob, any idea what colour stain is a good match for the original colour? cheers!
Hi here are some pics of my new recon OBD1 engine ive just bought to put in my 1998 highline Came out of a Mk3 with 71k miles on the clock and was removed due to failing its MOT on excessive chassis rust only. Last year the Engine had a rebuild, and has had various gaskets, a New reconditioned head with new valves set, seated, skimmed and crack tested etc. new piston rings, new big end bearings with arp bolts, Chain & tentioner had also been replaced along with a new water pump. Since then its been running in the car and had another oil change as part of 'running in process'. The engine wa
hi all just bought recon engine that has OBD1 throttle body and inlet manifold, with alloy rocker cover along with large black coilpack to use in my OBD2 highline. question is can i swap my inlet manifold, rocker cover etc onto the OBD1 block?, will it work with my ecu?, and will i get the increased 185BHP as opposed to the 174BHP of the OBD1?...or are the cylinder head/blocks different ?...dont want to loose any power! engine has been rebuilt with new recon head etc... hope someone can help otherwise i'll have to sell engine on! thanks
hi just bought recon engine that has OBD1 throttle body and inlet manifold, with alloy rocker cover along with large black coilpack to use in my OBD2 highline. question is can i swap my inlet manifold, rocker cover etc onto the OBD1 block?, will it work with my ecu?, and will i get the increased 185BHP as opposed to the 174BHP of the OBD1?...or are the cylinder head/blocks different ?...dont want to loose any power! thanks
1998 highline engine swap!
theboffin replied to theboffin's topic in Engine Maintenance and Problems
straight replacement for my high mileage engine in my highline, so my old one will be for sale soon... -
hi guys about to atempt my first VR6 engine swap, any advice on potential problems or wether i need to do any jobs in a particular way? i'm going to take off bumper, front panel and lights /rad etc so i can slide the old one out and then new one in! any advice greatly appreciated! cheers adam
my 1998 Highline, now with BBS RA's !
theboffin replied to theboffin's topic in Members Rides and Event Photos
no ideas, so having to swap back and sell these!!!!, infuriating! -
Unfortunately just went down the road after fitting, and grinding of callipers againt rim inner edge when brakes applied!!...i just realised that the brake disc and calliper size is bidgger on the late vr6's!!...loks like im buggered!...back to the RS$'s i guess? or could i space out the front wheels...any ideas anyone? -
Decided to sell my RS4 replicas..see Market Place and go for a more old school look!..always loved the original VR6 BBS RA rims, nice classic look!..so bought these today (thanks Mo!), more comfortable ride and no grounding with bodies in the back!
Highline AirCon fans problem?
anyone had a similar problem? -
Hi when i presss my AC switch air con compressor will not kick in until car is hot and high speed fans come in...i know that when pressing switch AC should kick the high speed fans on to enable the ac compressor to operate..any ideas?..checked all wiring, fine and fans kick in on and off when they should when engine is hot! help! cheers
Following my gravelly noise thread on my highline, things seem to be getting worse! Overflow tank has grey sludge for water, where oil appears to be mixing in and more worrying a copper particle sludge which resembles coppa slip?! Strange thing is it isn't overheating or running over normal temperature and oil filler cap is completely free of mayonaise?..it did have a bit when I bought the car but a bottle of kseal cured it. Otherwise car runs fine apart from noisy lifters when cold and gravely chain noise! ...told it could be mixture of oil cooler problem and head gasket breaking up? Cam anyo
Highline heated seats not working
theboffin replied to euanm1979's topic in I.C.E, Security an Electrical
Mines the same!..checked all relays and connections..nothing?
